BRU 07/09/2010
BRU 07/09/2010
Privilige Style B757-200 EC-HDS "VW Amarok Caddy" :
ETD. 09.15 as PVG 7821 to SZG
Re: BRU 07/09/2010
Special visitor tomorrow:
09:00 Titograd YM1215 (Montenegro Airlines) F100
Re: BRU 07/09/2010
Hello,VEX802 wrote:Special visitor tomorrow:
Was a ERJ195 4O-AOA
- tolipanebas
Re: BRU 07/09/2010
SN is using an all white A330 to substitute one of its own A330s (SFW?) which left for Malaysia to get a C check done....
Re: BRU 07/09/2010
Hellotolipanebas wrote:SN is using an all white A330 to substitute one of its own A330s (SFW?) which left for Malaysia to get a C check done....
CS-TFZ ( With XL titles )
- tolipanebas
Re: BRU 07/09/2010
It could be that one as I haven't bothered to check the registration; however, there are NO titles on the plane whatsoever, it is all white for sure.
SN must have had them removed then, I suppose.
Re: BRU 07/09/2010
I saw remnants of XL titles (only the L) on the right hand side of the fuselage of the aircraft, as it was standing at the end of the B pier. CS-TFZ is confirmed as the reg.
- tolipanebas
Re: BRU 07/09/2010
Would be great if this plane would get some temporarily SN titles and logo applied, don't you think?sdbelgium wrote:I saw remnants of XL titles (only the L) on the right hand side of the fuselage of the aircraft, as it was standing at the end of the B pier. CS-TFZ is confirmed as the reg.
Re: BRU 07/09/2010
Don't the African flights depart from pier A ?sdbelgium wrote:I saw remnants of XL titles (only the L) on the right hand side of the fuselage of the aircraft, as it was standing at the end of the B pier. CS-TFZ is confirmed as the reg.
Re: BRU 07/09/2010
Here is a picture of it. I have seen better work in the past of this photographer.
http://www.airteamimages.com/107143.html
Re: BRU 07/09/2010
No freight problems with CS-TFZ? It is an A330-200, not a -300!
It already operated SN237 yesterday, as I mentioned in yesterday's topic.
