TNT accident in BHX/Birmingham U.K.
Depretair
Post by Depretair »
A 737-300 of TNT made an emergency landing in BHX this morning.
The plane came from Liège/Bierset.
No injuries reported.
Any info about the registration?
Cheers
Olivier ;-)
teddybAIR
Post by teddybAIR »
Apparently they closed the runway as they foamed the runway.
Article can be found here: http://www.24dash.com/content/news/view ... ewsID=6918
And here a picture of the incident:
teddybAIR
Post by teddybAIR »
It seems that it's right main undercarriage didn't extend or lock down.
Good job by the crew on board!
SN BA flights to/from BHX have been cancelled or delayed:
Arrivals:
15/06 08:35 Birmingham SN 2050 Image 14:15
15/06 10:50 Birmingham SN 2038 Image
15/06 12:25 Birmingham SN 2040 Image 13:40
Departures:
15/06 07:45 Birmingham SN 2037 Image
15/06 09:25 Birmingham SN 2039 Image 10:19
Airborne
Post by Airborne »
Depretair wrote:Any info about the registration?
OO-TND
Advisor
Post by Advisor »
teddybAIR wrote:Apparently they closed the runway as they foamed the runway.
Why did they foam the runway :roll:
Was there a spill :?:
Aum Sweet Aum.
speedbird1
Post by speedbird1 »
Possibly a small fire or hot metal, due to metal hitting runway at 140 kts ish! Not a good mix.
Emirates
Advisor
Post by Advisor »
I can understand small fire or hot metal....but no mention of either a fire or the landing gear not functional, so must identify the cause of the foam....
Aum Sweet Aum.
grnkg
Post by grnkg »
A/c was due for landing at MME. During CatIII approach, autopilot was disengaged on short final. A/c slammed into runway, thereby ripping off RH LDG. The gear then slammed into the inboard flaps and aft fuselage.
Go-around initiated and after being airborne again, crew requested emergency landing at BHX due to weather conditions.
Krgds,
GR.
SN30952
Post by SN30952 »
Advisor wrote:Why did they foam the runway :roll:
Advisor, when you shave dry, it burns, isn't it.
Now when an aircraft makes an emergency landing, and the landing gear collapses, that impact may produce sparks, and if the tanks burst or leak, that may burn too...
It is a precaution.
btw
METAR for MME does not show some particular...
concordino
Post by concordino »
MME - any clue as to a name for the uninitiated.
C
concordino wrote:MME - any clue as to a name for the uninitiated.
C
MME = Teesside
concordino
Answered my own question. MME = Durham - Tees Valley (formerly Teeside).
Next question.Why would you then fly all the way to Birmingham when you could go to Manchester (80 miles closer) which has 2 runways so if a problem they could keep flying. Maybe the landing fee is cheaper at Birmingham?
Looks the flight crew will haves some explaining to do!!!
C
loutri666
Post by loutri666 »
Additional pics can be found here and here.
Seb
anjin
Post by anjin »
Rumour that it was EMA not BHX, the weather was poor so a diversion to BHX 40 miles away would be a very good idea
NeilArmstrong
Post by NeilArmstrong »
they diverted from stansted to east midlands (EMA) for a cat 3 landing ,this went wrong and part of a main gear was later found beside the runway there!
The aircraft diverted then to BHX where it made an emergency landing.
tire tracks where found in the grass beside the runway at EMA!
Neil
SN30952
Post by SN30952 »
concordino wrote:Answered my own question. MME = Durham - Tees Valley (formerly Teeside).
Did you mean: Teesside
Teeside looks something for golf :wink:
Depretair
Post by Depretair »
Is this plane making passengers flights too or is it only a cargo one ?
Thanks for the answer.
Olivier ;-)
Bottie
Post by Bottie »
Depretair wrote:Hello,
Olivier ;-)
When I see the pics, I think it's cargo only (look at the windowshapes), also the type: Boeing 737-301(F)
