Vortices?
Capt
Vortices?
Post by Capt »
Guys
I was wondering about this:
I was looking at the sky today and I was thinking about the white lines caused by jet exhaust (is this correct?).
Now my question about this is: What are they exactly, by what are they caused and at which height do they appear?
I'm sorry if this is a stupid question
Thx feedback
Regards
Capt
MD-11
Post by MD-11 »
Those white lines are called "contrails" or condensation trails.
If I'm correct it's caused by the hot exhaust gasses ( something about 600-800°C ). I think it's nothing else than ice chrystals. Imagine the air is -50°C, the exhaust gasses warm the air and it becomes vapour, when that vapour freezes you get ice chrystals and they form those white lines as you call it.
How long they become and stay up there has everything to do with the air temperature and humidity, I think.
At least that's what I think to know of it. :oops:
Anyone else another try... :roll:
Andries
Post by Andries »
MD-11, if my brain serves me well, I must agree with you 100%
:twisted: CanonFreak :twisted:
Capt,
What you are talking about is called a contrail and not a vortex.
One of the products of burning kerosene is water vapour. When this very hot vapour comes out of the engine it reaches very cold air. As you may know, hot air can contain more water vapour than cold air. When the hot air (with a lot of water vapour in it) comes out of the engine, it'll saturate the cold air and you'll get clouds who will be forming. The clouds are formed because of the condensation. When flying in higher altitudes the water dropplets will transform into ice crystals because of the very cold air.
The shape and length of those contrails only depends on the different layers of air you have. You can also have some pockets of air which are cooler etc....
The contrails usually appear when the plane is very high, because the higher you rae the colder the air, but there are exceptions ;)
Here are 2 pics that show some nice contrails that come out of an engine :
http://www.airliners.net/open.file/498094/M/
http://www.airliners.net/open.file/425100/M/
On the second picture you can clearly see that the contrail doesn't form itself directly behind the engine that's simply because the process is taking some time.
Contrails are not always produced by engines, but also sometimes by wings. This is due to the air cooling when flowing over the wing. This phenoma mainly happens when the humidity in the air is very high, which means that the air will nearly be saturated. In a result you'll get some condensation by cooling the air when flying through.
Here's a picture that illustrades the phenomena: http://www.airliners.net/open.file/270240/M/
As a side note, I heard a couple of weeks ago in a tv show, that on 11.09.2001, when all flights where grounded in the USA, the avergae temperature over the continent rose a litlle bit more than 1°C. By seeing this you can clearly see the impact that all those contrails have 8O
I hope I was able to answer your questions :)
Greetz
8)
EBAW_flyer
Post by EBAW_flyer »
You are correct about the high altitude contrails, there the difference in temperature causes the relative humidity to rise (and form condensation).
But this is not correct. Here the temperature does not change. The change in pressure makes the air saturated, not the change of temperature. As you know, above the wing there is a large area of low pressure (wich produces most of the lift). The pressure of the air drops and the relative humidity rises. So you get the same result: condensation (only here it are watter droplets and high in the sky ice crystals).
Very good explanations from all of you.
One more thing: the air in the engines is compressed to a high pressure, not only by the blades, but also because combustion increases the volume (and the pressure) of the gases.
When reverting to the low atmospheric pressure existing at high altitude, thegases undergo a strong cooling (in the same way as compression causes heating: check with your bicycle pump!) with transformation of the water vapour resulting from combustion into ice crystals. One more reason for the formation of contrails.
Skystef
Post by Skystef »
Avro wrote:Capt,
Indeed Chris that is correct, a contrail is made by the addition of water in the surrounding air, but don't forget that this air must be humid enough to produce contrails. Sometimes its to dry to form the "clouds".
Calculations can easely be made from the upper weather humidy charts to see if conditions are favorable for (persisting) contrails or not, and especially the military aviation is very interested and still make those forecasts. U probable know why ;)
SS
Capt
Post by Capt »
Guys,
this was very helpful
thank you for all the reactions
cheers
Capt
Thanks for putting it straight EBAW_Flyer ;)
Because they don't like to be seen, from far away :P
Ciao
8)
MD-11
Post by MD-11 »
When on vacation in Germany ( Kell am See, not far from Trier, to be exact ) I saw these nice contrails.
The latest pic is special with 3 contrails very close to each other 8O
OCR_ole_ole
Post by OCR_ole_ole »
Hi guys,
once our AC turned 45° to the LH as we flew into the stream of a BA 757 above the Alps... it was nice to see but scary at the same time.
This BA aircraft had to change alt and we were just behind... inevitable...
I never had such a nice angle over the snowy Alps
