BRU 14/07/2009
Mirror
BRU 14/07/2009
Post by Mirror »
STA1855 PGT273 Operated By IZAIR :)
Mirror
pjvdv
Re: BRU 14/07/2009
Post by pjvdv »
A bit late but Delta was N610DL ' Breast Cancer'
Re: BRU 14/07/2009
ETA 12.11 F-GMLU Blue Line MD-83 as JAF2711 from ALC (ETD 13.00 as JAF2943 to XRY/FAO)
ETA1855 PGT273 Operated By IZAIR
Should be TC-IZA
sn_rj85
Re: BRU 14/07/2009
Post by sn_rj85 »
pjvdv wrote:A bit late but Delta was N610DL ' Breast Cancer'
Do you have visual confirmation on that one?
Code: Select all
 ACARS mode: G  Aircraft reg: N712TW  [Boeing B752]
Message label: H1 Block id: 2 Msg no: D09A
Flight id: DL0140 [CVG-JFK-BRU]  [Delta Airlines]
Message content:-
#DFB*WOBJFKBBR5100G 1001061808M168M44037077209N51013W004492216045:
----------------------------------------------------------[ 14/07/2009 08:17 ]-
I doubt if it was N610DL, also because that one has no winglets and is not ETOPS
Re: BRU 14/07/2009
Well, ACARS shows it for DL125 (BRU-ATL), but that service usually continues to LAX. Maybe the ATL-LAX segment was operated by N610DL.
pjvdv
Re: BRU 14/07/2009
Post by pjvdv »
I think Sam is right :)
Code: Select all
ACARS mode: 2 Aircraft reg: N610DL [Boeing B752]
Message label: Q0 Block id: 1 Msg no: S25A
Flight id: DL0125 [BRU-ATL-LAX]  [Delta Air Lines]
concordino
Re: BRU 14/07/2009
Post by concordino »
According to my sources it was N712TW although I didn't actually read it off
C
Depretair
Re: BRU 14/07/2009
Post by Depretair »
When going to work, i have seen a B 757 of North American parked @ Melsbroek.
Any idea of the reg ?
Thanks
Oli ;-)
Mirror
Re: BRU 14/07/2009
Post by Mirror »
N754NA for NAO981 to KGTB
Mirror
