BRU 08/09/2010
BRU 08/09/2010
Privilige Style B757-200 EC-HDS "VW Amarok Caddy" :
ETA. 16.40 as PVG 7822 from SZG
Re: BRU 08/09/2010
Hifly A330 CS-TFZ ( XL titles ) flying for Brussels Airlines:
ETA. 05.20 as SN 204 from BJL,DKR
torchus
Re: BRU 08/09/2010
Post by torchus »
UA973 just took off from rw02, all other planes took off from rw25R, why would that be ?
airbuske
Re: BRU 08/09/2010
Post by airbuske »
tangolima wrote:Hello,
Delayed till 09/09/10 ETA 2:50 as SN1204
Airbuske
teddybAIR
Re: BRU 08/09/2010
Post by teddybAIR »
Rumour has it that American planes occasionally choose for 02 instead of 25R because of obstacle clearance regulations applicable to american airplanes. Probably minor differences between FAA and JAA regulations that determine whether a take-off can be made within regulatory limits or not.
bAIR
Re: BRU 08/09/2010
When flying to the US, isn't an 02 departure a few nm shorter then a 07R departure?
torchus
Re: BRU 08/09/2010
Post by torchus »
teddybAIR wrote:Rumour has it that American planes occasionally choose for 02 instead of 25R because of obstacle clearance regulations applicable to american airplanes. Probably minor differences between FAA and JAA regulations that determine whether a take-off can be made within regulatory limits or not.
bAIR
What do you mean exactly by obstacle clearance regulations ? I'm not so familiar with aviation terminology.
Re: BRU 08/09/2010
At the end of some runways are obstacles, like trees or electricity lines. It could be that American and European regulations differ in the height at which an aircraft should overfly these obstacles when departing from that runway. It is possible that the American rules are stricter than the European rules and therefore, let's say AA cannot takeoff from that particular runway (in some cases).
torchus
Re: BRU 08/09/2010
Post by torchus »
Thanks for your answer, but why would that be the reason the plane departing from rw02 ? Or are these regulations possibly time or weight-dependant, so that rw25R cannot be used by some airlines during some times or when the plane is heavily loaded ?
And these obstacles, are these only near-field, or also far-field ? And about which altitudes are we talking then ?
Additionally, rw02 is a lot shorter than 25R, so I would think that the obstacles are more of a problem when taking off from 02.
Re: BRU 08/09/2010
Passed along the Haachtsesteenweg shortly before noon today, and saw something like a B737 with titles about something Pacific and CS-registration. What is it and what is it doing there, at the east end of the military apron?
Re: BRU 08/09/2010
HiFy A310 CS-TEI (not sure of the reg), PacificFlier titles.
Re: BRU 08/09/2010
Thanks for info, SDB. Shame on me for mistaking an A310 for a B737 - you can see I was in a hurry!
