Re: Abnormalities in BRU-ANR-CRL-LGG-OST in 2014
Does anyone know what's going on with flight TCW9612 ?
AC is SATA A320
- tolipanebas
the pattern looks like the one used by planes for a maintenance release flight...
the flight number too, BTW.
At what kind of altitude (or, more likely, at what flight level) would that typically be flown?
This morning, the 07.30 Jetairfly flight Charleroi-Alicante was announced as delayed until 11.30.
Cause of the delay, given on the PA :
- in French : "panne électrique"
- in English : "power failure"
Looks like SN1453 to KGL (departed 11:18) is in holding over Belgium since a couple of hours: http://www.flightradar24.com/BEL1453/4c1a554
Brussels Airlines just tweeted that SN1453 has a minor technical issue and preferred returning to base.
Apparently a problem with one of the three hydraulic systems of OO-SFU.sn26567 wrote:Brussels Airlines just tweeted that SN1453 has a minor technical issue and preferred returning to base.
Deux bâtiments techniques de Belgacom ont été visités par des intrus qui ont coupé des câbles de cuivre et de fibre optique, samedi soir. Plusieurs milliers de clients de la province de Hainaut sont actuellement privés de téléphone et d'Internet. Les premières connexions ont déjà été rétablies mais la réparation totale du système prendra "un certain temps".
Charleroi airport affected by a sabotage at Gosselies yesterday evening : many Belgacom cables have been cut, making u/s telephone, internet, Bancomat and other networks.
http://www.lavenir.net/article/detail.a ... 9_00555861
http://www.rtl.be/videos/video/514425.a ... goryID=286
Report Aviation Herald:sn26567 wrote:Apparently a problem with one of the three hydraulic systems of OO-SFU.sn26567 wrote:Brussels Airlines just tweeted that SN1453 has a minor technical issue and preferred returning to base.
http://avherald.com/h?article=47cfc1ab&opt=0
What avherald didn't report is that about 50 of the passengers were rebooked on the Ethiopian 787 (flight ET705) and will have enjoyed a much more recent aircraft. I don't know about the other passengers...Passenger wrote:Report Aviation Herald:sn26567 wrote:Apparently a problem with one of the three hydraulic systems of OO-SFU.sn26567 wrote:Brussels Airlines just tweeted that SN1453 has a minor technical issue and preferred returning to base.
It's not all about how recent an aircraft is in terms of passenger comfort and on board service and experience though. And I don't know if the dispatch reliability of the 787 is higher than that of the SN A330 fleetsn26567 wrote: What avherald didn't report is that about 50 of the passengers were rebooked on the Ethiopian 787 (flight ET705) and will have enjoyed a much more recent aircraft.
- HQ_BRU_Lover
As also stated on aviation herald: no fuel dump? Just because of the hydraulic problems?
OO-SFU is not equiped with a dump system.HQ_BRU_Lover wrote: no fuel dump? Just because of the hydraulic problems?
Reason: BBCode re-enabled
- HQ_BRU_Lover
Didn't know, that: interesting! So the fuel dump system is not standard on 330's or is it neither on other aircraft?
FR-2925 Brussels-Lisbon : scheduled 07h25, departed at 15h06
FR-2926 Lisbon-Brussels : scheduled 13h35, expected arrival 20h54
Flighstats says "Tracking is not enabled for this flight". It was probably just a minor technical issue?
United Airlines flight UA951 (B777-200 reg. N777UA) from Brussels to Washington is diverting to Iceland.
Brussels-to-Dulles Flight Stops in Iceland for Medical Emergencysn26567 wrote:United Airlines flight UA951 (B777-200 reg. N777UA) from Brussels to Washington is diverting to Iceland.
A plane is expected to land at Dulles International Airport about 6:30 p.m. after it was forced to make an emergency stop. United Airlines Flight 951 took off from Brussels with more than 200 people on board.
During the flight, one of the passengers had a medical emergency, and the plane had to land in Iceland to get help. The patient’s condition is unknown.
Source: NBC
It seems that the passenger passed away. Body was just carried off the aircraft at KEF. (Source: Joost Freys of HLN)sn26567 wrote:The patient’s condition is unknown.
Due to bad weather conditions at Krakow Airport, Brussels Airlines flight SN 2548 to Brussels Airport is cancelled.
