The one and only topic on which runway in use @EBBR
ZavCity
Re: The one and only topic on which runway in use @EBBR
Post by ZavCity »
A very good question and how are they backtracking now...? and very strange indeed, they all fly over my house now in Zaventem..
gtz
paul
No, they can still vacate via C2 as the SN below did minutes ago. About 1200m from TD.
Alternately, use C3 for a safety belt check.
Not sure you could vacate via C1 as you'd need to use TWY V1 which is only 20m wide.
ZavCity
Post by ZavCity »
Thanks a lot for this very interesting info!
gtz
paul
Wind change: from now ARR 07L - DEP 07R
Again ARR 07L - DEP 07R (coming from 01/07 this morning)
Northeastern winds: ARR 01 - DEP 07R
Homo Aeroportus wrote: 31 Mar 2019, 11:57
There are no restrictions on V1, except 747-8 and A380. Of course, some pilots prefer not to use V1 due to its narrowness, but that’s pilot’s discretion.
Strong northeastern winds: ARR 07L - DEP 07R/07L
ARR 01 - DEP 07R
sn26567 wrote: 15 Apr 2019, 11:34 ARR 07L - DEP 07R/07L
Change to ARR 07R - DEP 07L
Recent change to ARR 01 - DEP 07L/07R
01/19 closed due to works
The day started with moderate eastern wind and runways 25L and R. As the eastern wind increased, now Rwys 07L (Arr) and 07R (Dep).
If wind conditions remain as they are, the 07 runways will permute at sunset: 07R for arrivals, 07L for departures.
sn26567 wrote: 22 Apr 2019, 17:20 If wind conditions remain as they are, the 07 runways will permute at sunset: 07R for arrivals, 07L for departures.
What's the point of doing that?
Sharing out annoyance as evenly as possible, I should reckon. The spirit of Bertje hasn't entirely evaporated, as yet :)
ZavCity
Post by ZavCity »
No ILS on 07L...After dark, landings on 01, just near my home!
gtz
paul
convair wrote: 22 Apr 2019, 18:10
EBBU wrote: 23 Mar 2017, 07:53 The arrival procedure for 07L is an offset VOR/DME, with a last visual part. This is not available after sunset (07L has no approach lights).
That is why after sunset RWY 07R is used with a straight in VOR/DME. And with a loss in capacity due to bad exit TWYs.
Explanation of 2 yrs ago, is still valid.
DIBO wrote: 22 Apr 2019, 20:47
Thanks DIBO. Don't be too surprised if I ask again in 2 years from now: my memory isn't improving... ;) :)
How much does an ILS and landing lights cost for 07L?
Maybe it's cheaper than adding / rebuilding exits on 07R?
Better for Zaventem City Centre as well...
