Spotters,
too many topics are opened to ask for runway-usage at Brussels EBBR airport. Please ask runway usage in this topic.
thanks for cooperation
Spotting guide Brussels Airport: viewtopic.php?f=21&t=56798
Zorba
Post by Zorba »
[Status 07/11] @ 8h55 local Time :
- 25L / 25R for arrivals
- 25R for departures
Note : Change to 02 / 07R could be possible
Current winds : 020° @ 2 knots!
Tot hier en verder
RobinZartos
Post by RobinZartos »
I know it's a bit early but sumeone knows the runway usage for today (11/11) ?
blackhawk
Post by blackhawk »
Well, I think it's the 02 beacause they are flying over my house ...
ATM= Haze, 4°C, feels like 2° C, ENE (60°) 10km/h, visibility 4km, dew point 3°C, humidity 93%
Expected= Partly clouded, 10°C, ENE 18km/h
Have a nice day
Zorba
Post by Zorba »
Nothing over my house, so probably 02 like blackhawk said!
Weather : overcast (had some sun at around 9 am). Not very good spotting weather. Tomorrow will be much better!
Tot hier en verder
Glider
Post by Glider »
It sure is 02; I already have been spotting out of my window ;-).
RobinZartos
Can someone please say me wich runways are in use for tk and lnd. (21/11)
liebensd
Post by liebensd »
Robin,
Maybe this can help you? Brussels runway configuration tool
Greetz,
Dave
RobinZartos
Thank you fabk... uh Dave :wink: but that tool only gives one runway, and i can't know if that runway is for take-off or landing.
liebensd
Post by liebensd »
Robin,
If there are low wind speeds, less than 5 to 10 knots than is the dispersion plan the only solution and the take off and landing runways are given. For higher wind speed there is a system that looks at the cross and tail winds and with this info it decides wich runway(combination) is the best. So then there is no info of taking off and landing, but in normal situations when 25L/R is in use 25L is landing and 25R is a combination of both. There are also combinations possible with 25L and 20 like last summer when 25R was in maintenance, but these situations are almost not able to be included in the system.
Greetz,
Dave
Kapitein
Post by Kapitein »
At this moment is 25R in use for landing and 20 for take-off.
25L closed
Lyulka
Post by Lyulka »
Brubiac wrote: 25L closed
Is this due to ILS calibration?
If so, does this mean that 25R will be closed in the afternoon?
Kapitein
Post by Kapitein »
25R is now for landing and take-off, 20 only take-off.
No idea why 25L is closed.
Skystef
Post by Skystef »
Brubiac wrote:No idea why 25L is closed.
Isn't it every Sunday closed between 06:00 and 17:00 local time due to the dispersion plan? I guess so, unless the wind speed & direction doesn't allow to follow this plan.
Brgrds S
A340-600
Post by A340-600 »
hi,
I'am going sometime spotting at asielcentrum in brussels or in Nozzegem, I dont now the runways by name. I got very nice pics there, my first times
I use a Sony F717, its a good camera.
ehamspotter
Post by ehamspotter »
hello;
Dus someone knows wich runways are in use at 5/1/05?
Best regards: Jeroen
Skystef
Post by Skystef »
ehamspotter wrote:Does someone knows wich runways are in use at 5/1/05?
Wind forecast is provided in the calculator, maximum outlook 24 hours.
To have a clue beyond 24 hours check out some weather sites. In my web there is a 1-3 day forecast for wind direction via this link. An overview of the other forecasts & current weather viathis link.
Concluding SW'ly wind on 05/01/05: so normally 25L for landing, 25R for t/o.
Rgrds S
ehamspotter
Hello;
Thanks skystef
regards:Jeroen
Kapitein
Post by Kapitein »
ehamspotter wrote:hello;
Landing 25L and 25R
Take off 25R
wind is 210°/07 knots
Zorba
Post by Zorba »
So a change to 20 could be possible?
During forenoon they will swith to 02, but when exactly I don't know. It starts with a windspeed exceeding 6KT. By the time of departure, for surely rwy 02/07L/07R will be in use and the USA will depart on 02 . So you have 2 chances.
Tot hier en verder
